Some of my articles do not have pictures. On the homepage, a placeholder image is loaded, but when I go to the article, there is no featured image and it cuts off the title and information above the article. Can someone please help me adjust this to display properly?
Thanks,
Dan
You need to edit the single post template using the tagDiv Composer, click on the content row and set some margin top like this -> http://prntscr.com/pvryye adjust it for other devices too -> http://prntscr.com/pvrz9x
Let me know the results!
Thanks Calin. I got that working, can’t believe I didn’t find that earlier.
I have another question though. I’m using adrotate and the ad plugin to cycle a few ads. It displays perfectly fine on my homepage, but on articles it briefly flashes then disappears. The links still work however. Could you give me some idea on what might be causing it? An example can be seen here.
Thanks again for your help.
Is look that the ads appear, but the background color from sidebar will cover it, please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
