Article top ad and article bottom ad too narrow
On this page – https://jazzjournal.co.uk/2020/04/27/jj-04-60-in-my-opinion-eddie-harvey/ AdSense ad code entered into Article Top and Article Bottom fields don’t produce full widths (I want something like the Header ad). It doesn’t matter if I specify width at 728 x 90 or set format to auto. It only gives a narrow, small horizontal ad, say 50% of the size I expect. I want the ad the same width as the text below it. Can anything be done about this?
Detail:
I put this code in Theme Panel/Ads/YOUR ARTICLE TOP AD (note the specific dimensions: width:728px;height:90px):
<script async src=”https://pagead2.googlesyndication.com/pagead/js/adsbygoogle.js”></script&gt;
<!– JJ display horizontal 1 –>
<ins class=”adsbygoogle”
style=”display:inline-block;width:728px;height:90px”
data-ad-client=”ca-pub-7426344127145001″
data-ad-slot=”2925354814″></ins>
<script>
(adsbygoogle = window.adsbygoogle || []).push({});
</script>
I put this code in Theme Panel/Ads/YOUR ARTICLE BOTTOM AD (note the unspecified dimensions: data-ad-format=”auto”):
<!– JJ display horizontal 2 –>
style=”display:block”
data-ad-slot=”8739066075″
data-full-width-responsive=”true”></ins>
<script>
</script>
I now see I can adjust size in Theme Panel/Ads/YOUR**AD/Advance Usage.
But above that parameter Theme Panel says: “If you leave the AdSense size boxes on Auto, the theme will automatically resize the Google Ads.”
Is the theme no longer resizing AdSense ads? I wouldn’t have thought AdSense would intend them to be so small.
For your info, I have now reverted YOUR ARTICLE TOP AD to data-ad-format=”auto” as using Google’s fixed size has no effect.
Lastly, I have placed code in the Footer Top field but no ad appears:
<script>
</script>
MG
Hello !
Please note that if you let the option on auto, Google will show the ads that he thinks that fit the best for your users experience. Now the ads seem to appear on your wesbite. Please clear your cache and let us know !
Thanks – and the Footer Top ad? I am still seeing no ad above the footer.
Hello !
You mean this one: https://www.screencast.com/t/tq5irhTAf3
Hi Vlad – no, that ad is set Theme Panel/Ads/Article bottom ad. I mean the Footer ad set at Theme Panel/Ads/Footer top. I have placed this code in the field YOUR AD CODE:
<script>
</script>
but nothing appears.
Mark
Hello !
– admin url and credentials
– cPanel url and credentials
Please note that due to high number of requests the response time can be delayed up to 48hrs.
