Hi support,
I would like to use the different adspots in articles / posts.
Right now I am trying to get a banner (300×250) to be shown here: “Article top ad”.
But nothing happens… :-/
I am using this code:
<div class=”td-all-devices”>
</div>
I have read the article: https://forum.tagdiv.com/using-other-ads-non-adsense-ads/
Thanks 🙂
/Twolle
I will here split up the code a bit, so you can better see it:
<a href="https://servicenews.dk/medlemsnyheder/" target="_blank" rel="nofollow">
<img src="https://servicenews.dk/wp-content/uploads/2020/04/Magento-shop-kommerce-Webshop-Pressemeddelelse.jpg" title="Nyheder om servicebranchen"/>
</a>
</div>
……… hmmm….it didn’t work for me :-/
Hello !
Please make sure that you have inserted you code properly. As you can see here everything works fine on our side: https://www.screencast.com/t/SbscFkLdXHP ; https://www.screencast.com/t/ix6SCWw8mb
Hello !
Please make sure that you’re inserting the code in the proper way: https://www.screencast.com/t/ZonfWIPkgeq Follow our guide for more: https://www.youtube.com/watch?v=biTpVVlr8j8&t=3s
From the Theme Panel I can get the “Header Ad” and “Sidebar Ad” (using “Custom ad 2”) working. But not the 3 article ads.
Changing the template for the single posts makes the article ads working.
It is a bit confusing that something works from the Theme Panel and something else work from the templates. Maybe I just don’t understand the fundamentals of Newspaper :-/
But thanks – I got it working with your help.
/Twolle
