Articles at top of front page wont click
For some reason the articles on the slider part of my homepage http://www.irkitated.com won’t click to visit the post. This only happens for the ones on the slider, the rest are fine.
The only thing I can think that I did was update to the latest version of Revolution Slider but after contacting them directly they told me that isn’t their product on my homepage.
Do you have any ideas how i can fix this please?
This issue happens when using the Google Analytics by Yoast plugin and looks like that some how the plugin is affecting the html structure.
I have checked your site and noticed that you also use it: http://screencast.com/t/xhvaMgaAR
We have already wrote to plugins author so we can find a solution for this, you can also write to their support page: https://wordpress.org/support/plugin/google-analytics-for-wordpress
We are trying to fix this but unfortunately is more difficult than we initially tooth. You can deactivate the plugin in order to make links work and until we find a solution for this.
  • This reply was modified 12 years by Lucian.
Thanks for the update. I’ll take your advice and disable the Yoast plugin for now.
Thanks for letting me know so quickly! I’ll wait for the updated version of both.
Cheers,
I have deactivated the plugin and emptied the cache but that doesn’t seem to have fixed the issue.
I have check your site and noticed that you still have this plugin active: http://screencast.com/t/12YYLGr3V
Please disable it and then let me know so I can inspect this.
Nope, it is definitely deactivated! I just activated and deactivated it again.
http://imgur.com/4KyPdPL
Could it have permanently altered the html structure in a way which doesn’t change back?
Check this: http://screencast.com/t/VaHoL4H1i8 or you can only uncheck this option from plugins settings: http://screencast.com/t/Ig3UZF4x
You can also use our Google Analytics feature from here: http://screencast.com/t/Mp9f307tXRzo
Ah my mistake!
Thanks for the screenshots. I have now deactivated as you showed and the site can be clicked again now.
Thanks for your help.
  • This reply was modified 12 years by irkitated.
