Hello, articles auto loading having a problem. It should auto load only the article its self. Instead it loads menu, and everything else around. The whole page. We do livestreams and we place the embed above articles when we do, and when it auto loads it shows again. Imagine when this happens. What can we do?
First of all, please make sure the issue is not from a plugin conflict or a cache issue, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache (also from your browser) and try again.
Also, please provide the link to your website.
The thing is that not only it shows again the menu. But when i place our html embed livestream it shows this one too. How can we show only the next article, without getting the embed and the menu again?
I checked and now seems the option for infinite loading doesn’t work, did you disable it?
Also, I saw you have a lot of errors in the console.
Also, please provide some screenshots of what you see.
Unfortunately, I saw you have a lot of errors on the console https://i.imgur.com/6JTASaM.png caused by a plugin. I think the problem is caused by a plugin, not the html embed livestream.
