We just implemented the infinite scroll option for the posts of https://www.flipa.net/ and we found 2 problems:
1. The URL does not change when you scroll from one post to another (neither on desktop nor on mobile)
2. Despite having indicated 5% in the ‘Page scroll percent’, the posts take a long time to appear and the speed of the site has slowed down a lot.
Can you please give us support (especially in the first issue)?
Pleas make sure that you set the settings for Infinite loading like this -> https://www.screencast.com/t/b4nsaLI32Yt ->https://tagdiv.com/infinite-loading-for-single-posts/ after that set that post template on some posts https://www.screencast.com/t/kpOorgwvJqF and the results should be like this -> https://www.screencast.com/t/xoDsxMAK4uT8
Making these settings the link in url should change and the loading should work normally ( set 5 not 5% ).
Please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
