articles (posts) chained together
Hey,
I have a weird issue that I am stuck on.
When scrolling to the bottom of an article (post) it just immediately leads into another article, and another after that, and another, etc. each article should just be independent pages to avoid loading issues.
Any advice?
https://arcadianmedia.com/2020/03/14/lec-cancels-live-studio-and-press-origen-will-not-travel-to-berlin-studio-and-will-play-matches-online/
I’m assuming that this problem appear on posts that have set infinite loading, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
Thank you for your help. That fixed my issue!
