Assigning domain problems
I have a problem assining the two websites i can use with your theme i bought from Envato. After i assign it on the stagging website i work says is assign but whern i try to use the cloud templates says is not assigned. I cannot assign it or unnasign it onto the two websites. I reset the key and introducing it again but still nothing works. I need it solved urgently.
Please go to the My License section and assign the domain that you want -> https://i.imgur.com/TxINWwn.png
I tried already and it does not work. read what i wrote.
Can you please provide a screenshot?
