Assistance Required for Disabling Posts Loop Section
hi,
I am experiencing an issue with the posts loop section on my WordPress site. Despite my efforts to adjust this section using the TagDiv Composer editor (as highlighted in the red circle), I am unable to make the desired changes. Additionally, when I try to set the “Number of pages to display on the blog” option to 0 in the WordPress settings, it does not save the change and prompts me to set a minimum value of 1.
Could you please provide guidance on how to completely disable or hide the posts loop section at the bottom of my site? I would appreciate any help you can offer.
Thank you in advance for your assistance.
View post on imgur.com
  • This topic was modified 2 years by yavuz.
Please edit the page normally in editor and change the setting for the page into Template: Default template because I think you have there the setting: Pagebuilder + Latest articles + Pagination and these are not editable by the tagDiv Composer plugin.
Hi again,
I didn’t expect such a simple solution to this issue! Thank you so much for your help.
Don’t hesitate to contact us if you have other questions.
Have a great day!
