Assistance Required for Integrating KK Star Ratings in Post Loop
i dont want to use your builtin review forms https://prnt.sc/6GPWXzE8RIbj
data showing from review forms i want to change it make it shows from kk start rating plugin shorcde https://prnt.sc/DFeaIG2E8caj
For customization and other services, contact our custom work team here: https://tagdiv.com/premium-customization-services/.
Thank you so much for your understanding!
i don’t need it, you guys charged over thousand dollar
just tell me how can i do
Unfortunately, we do not have any option in our theme to change the post loop as you need.
Only a shortcode can let you add a new block from an extra plugin.
A shortcode can be inserted using the element “Column text” or “Text with title”. “Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open, and you can add some text/code/shortcode there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
