Audio" input format in post
Is it possible to activate the input format for audio in the inputs?
Now it is only possible to select Galeria, Esandard and Video.
http://efmr.cat/Formato-de-entrada.jpg
In the “theme” that we had previously if we could make this selection, but when changing to its “theme” we have realized that it is not possible.
It is important for us, we are a radio station, and our contents are based on audio.
Hello !
Unfortunately this option is not available as standard for Newspaper Theme. Maybe you can achieve this using a plugin. You can try it out but we do not have tested any plugin and we cannot offer support for untested plugins. We are sorry for the inconvenience !
Do you know any plugins that can activate this function?
Thank you
Hello !
Unfortunately we haven’t tested any plugins of this kind in order to recommend some.. You can try to see wich fits you best and also make sure not to get in conflict with other plugins.
