Author Box Below Related Posts in Posts
Hi. I just updated “Newspaper” to 9.7.3. Can’t figure out how to push Author Box below Related Posts in post pages in the Responsive version. Please help.
Best Regards
Narinder
That can easily be done if the post uses a cloud post template
https://cloud.tagdiv.com/#/load/Single
It is a matter of drag and drop while editing the cloud post template
http://prntscr.com/nvdssjhttp://prntscr.com/nvdt1o
For default post templates it would require modifications in the code structure, and this can’t be done in a child theme after theme update 9.7.
Thanks but I will need to modify the code because I do not want to use a cloud post template as of now (no template is good for the image size of 670x446px). In the earlier version of the theme, I had made the change in the ‘loop-single.php’. Now, this file seems to have changed because I could not locate the code for the related posts. I am not using a child theme and I am willing to manually make this change every time the theme gets updated. I need to show related posts above the author box. Please tell me where to make the change.
Best Regards
You could do that, the post template files are now here – http://prntscr.com/nvui9l
The cloud post templates can be modified in the composer, and the featured image can be changed if needed – http://prntscr.com/nvujaw
You can modify the templates that you import, or design your own using the blank single template.
