Author box on single posts inconsistent
If you want to add an image for oyur Author Block, you need to use the WP User Avatar ot Gravatar. Please check here -> https://en.gravatar.com/site/implement/images/
We figured it out. We had a post that was not using the default template.
Thanks again!
