On many of your blocks, such as “big grid 8” and “block 25,” the author name appears just on the larger images. I have a site where author name is of equal importance with post title. Can I alter these blocks so that author name always appears along with post title? There appears to be more than enough room on the images for this. Thanks.
Hello jauburn,
If you want to make these modifications, please notice that you should alter the get_title function in order to bring the author after the title. As a quick solution, please notice that you have to follow the next steps, like this -> http://screencast.com/t/WoXD4CtVXZ Please notice that you have to concatenate that code for each case at this function for bringing the good results. As you can see, this is not a simple task and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
The code is -> ' By '. '<a href="' . get_author_posts_url($this->post->post_author) . '">' . get_the_author_meta('display_name', $this->post->post_author) . '</a>'
