Hello
author link not ??
http://www.sessizgultekno.com/author/isitmengelliyim/
author page not error?
look picture
https://postimg.org/gallery/v1ph14xu/7cd0901f/
help please
thanks
It seems you have a redirect on your author link. Please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
