With the latest theme update, I find that the options are not working well. Example: I had to set up my site again once I updated to the new theme version. Now I am left with the author showing on each post even after I have disabled the author option and the author box option. Please help. Thank you.
I just checked on Newsmag last version and for me it is working correctly, to remove the author from posts I used those theme panel settings – https://i.imgur.com/Bgi2DmC.png
Can you please provide some screenshots and a link where I can check it? Maybe the author is displayed in a block, in this case you’ll need to use this option – https://i.imgur.com/ZZRRvF9.png
Yes, we can check it via email, please contact us at contact@tagdiv.com and please include in the email the link of this topic and also please provide a temporary wp-admin access to resolve the problem.
Hi Sebalos, usually when this is happening is related to a cache/object cache that is apply on backend and when the page is reloaded the theme panel settings will be delivered from cache version – https://i.imgur.com/kPuffg6.png
