Author Show Problem
I am Now Use The Default Demo and off The Author Show option But Now Show The Author Name<
dainikbarta24.com this is my website,
AS I can see you are no longer have the author in the posts, -> https://i.imgur.com/pBbEDoM.png -> https://i.imgur.com/ADiejy1.png if you want to remove it from the homepage blocks too, then you need to use these options -> https://i.imgur.com/uS0adrG.png, if you are using cache plugins, clear it and check the results.
If the problem persist, make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
