Dear Mr.
I pasted my google auto ad code into ‘analytics/js codes’ area. Vignette and Anchor banners are working well. BUT In-Page ads not working on mobile and desktop!!!!
By the way, AMP ads working well! (there is no any issue)
I started using this theme last week. In my old theme, I was using google auto ads without any problems.
I read all forums to find a solutions but I couldn’t. Please help to resolve this issue.
I just checked your website and on mobile, on homepage the auto ads are displaying -> https://i.imgur.com/8BhSHAU.png -> https://i.imgur.com/l1B4RiH.png
is this your perfect answer? it’s quibble! MOBILE ? MOBILE ? MOBILE ?
I used your ad space because auto ads did not work. That’s why you see homepage’s ads.
Please check it again. And Give me a solution.
Indeed there seems to be some problems, please send us an email at contact@tagdiv.com and provide admin login. We will take a look to this problem an will provide a solution. Include a link to this topic in the email.
Dear Calin,
I sent you an e-mail and provided my admin login informations. Please check
Thanks for your concern.
Calin,
I don’t think you really care about my problem. Your sustainable answers are provided to save time. And your reply back to every message takes a day. I am still waiting for my problem to be solved for 1 week. And nothing has been done so far.
Please see the message your friend wrote to me.
Make sure that the code for auto ads https://i.imgur.com/lbLzYAB.png is activated in your google ads account because now there is not auto ads delivered.
Alex N.
Dear Alex,
how can you be sure of that? If you checked my webpage, you should have seen some google ads appear. For example; homepage auto ads are working on Desktop.
And Vignette and Anchor banners are working too.
My google ads account is ok and there is no any issue on that side. I also had no problems before I switched to your theme.
It takes a day to answer every message. And I have been waiting for you to solve this problem for a week.
Please continue the discussion on email.
There was a delay in our answers caused by the theme updated, we try to answer to each customer as soon as we can, also we answer to the topics/emails from the oldest to the newest.
Thank you for your understanding and sorry for the inconvenience!
