Good evening,
please could you tell me how to disable (something i have already enabled but forgot how)?
it is something that “charge” (automatic load more) all the posts into my page, you can see it by scrolling down, after the post then facebook, then comments!! just there! where i need to get rid of this and show directly the ‘Big Grid Flex 1’ with the videos at the end. http://newwebsite.rplfrance.org/2020/09/01/emmanuel-macron-au-liban-jaj/
Thank you
That is the infinite load for posts. Please edit the cloud post template with the composer and disable it if you do not want to use it
https://prnt.sc/ubfu3j -> https://prnt.sc/ubftij
