Auto load next page / post on mobile
I am using this theme and I would like to add a feature that makes the next article autoload once a reader has scrolled to the bottom of a post.
This can be seen when viewing articles from http://www.birminghammail.co.uk on mobile.
Are there any plugins / easy ways to do this?
Hello thomharvey,
Unfortunately, our theme does not have such an option for this, sorry! Please keep in mind that this task is not a simple one and it can be made only through hard working but please notice that this request involves custom work and we cannot provide this type of services at the moment, sorry! If you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you or you can try to find some plugins with this functionality and see how it will work for you. Unfortunately, we cannot make any recommendation in this regard because we do not have tested any plugin in this regard.
I am trying to achieve the same thing with the help of https://wordpress.org/plugins/auto-load-next-post/ but its not working.
Hello wpmu,
Unfortunately, this type of plugin is not tested with the theme and we cannot say for sure if it will work as expected, but also, you can try it and check the results. Please notice that our types of paginations can be found in Block Settings, like this -> http://screencast.com/t/ISLQyysuYMv and also, for post pagination you will have to use the following code in order to achieve it, according to our documentation here -> https://forum.tagdiv.com/posts-with-pagination/
Please notice that any other type of pagination requires additional customizations that involve custom work and we cannot provide this type of services at the moment, sorry!
If you want to display more levels in our theme and you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you!
