Hello mrcbt,
Unfortunately, the only available settings from category can be found here -> https://www.screencast.com/t/TlxCYb1FGc We do not recommend using another plugin with this functionality because we cannot say for sure what exactly will works.
Hello Catalin,
I’m not talking about categories. I’m talking about the post it self.
Example: https://qz.com/1218921/holi-semen-balloons-bollywood-turns-festival-of-colours-into-orgy-of-sexual-violence/ just keep scrolling down, new posts will show up.
There are a couple of plugins that do this in WP, but I couldn’t get it to work with this theme.
1) Sofa Endless Post
https://codecanyon.net/item/sofa-endless-post-single-autoload-older-posts-for-post-single-page/18533344/comments?page=2&filter=all#comment_18890984
The dev said: “As I recall that theme uses non-standard Post headers which are not the part of Post but rather extracted separately in order to be displayed on top of the rest of the content (including the sidebar).
The plugin hasn’t been updated since it works fine with the current version of WordPress.”
2) Auto Load Next Post
https://wordpress.org/plugins/auto-load-next-post/
Hello mrcbtm,
Unfortunately, the theme has no option for the infinite scroll for post pages, sorry! Also, the theme does not have any such a tested plugin in this case and that’s why we cannot make any recommendation in this regard, sorry! This functionality is too complex and it’s not easy for the implement. You should do it yourself and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
