Avatar and Single Post Author Box
I have set my avatar using the plugin “Simple Local Avatars” as described on your website.
Before setting, the display was as follows (Single Post Author Box),
but if you set the avatar, the display was broken as shown below, and the avatar is not displayed.
Dashboard – Users – Profile:
I also tried this plug-in below, but the result was the same and the display was broken.
Could you guess why..?
https://blog.sumemiya.net/2022/10/20/eminem-stronger-than-i-was/
Thank you for your help again!
Amie
I just made some tests and for me is working without problems – https://i.imgur.com/pkmqzdC.png as a plugin, please try the Simple Author Box plugin.
Also, if the problem persists, please try only with tagDiv plugins.
Let me know the results!
Hello Calin,
Thank you for your support!
It took a while, but finally the Avatar image was displayed.
1) The plugin “Simple Local Avatars” described on your website, unfortunately didn’t work in my case, probably because of a cache issue.
I uploaded the first time a too large image without cropping by my mistake,
and after that, deleting it and uploading a new image, but it never showed up.
Instead you see a very large empty space there.
I cleared the cache, but it didn’t solve it.
But it seemed to be displayed correctly on different browsers or devices than I normally use.
… so I think it’s because of the cache.
2) I tried using the plugin “Simple Author Box” you wrote.
In this case, the original Author Box of this plugin was displayed, so I put off using it.
3) I tried the “One User Avatar” plugin again and this time it worked and the avatar appeared in the Single Post Author Box of TagDiv Composer as I wanted.
(I wrote the progress for the user’s reference.)
Thank you very much for your support!
Amie
Thank you for sharing the steps you did!
