avatars & author box not showing up on posts
My avatars are not showing up next to my comments on posts. Also, my author box is also not showing.
I have checked & unchecked the “show avatars” option under the discussion setting but that has no effect.
Where else can I check this?
Link to the pages : http://testing.travelhippi.com/cullinan-best-daytrip-gauteng/
  • This topic was modified 8 years by travelhippi. Reason: included a page link
There seems to be a code that prevents the avatars from displaying, as well as the author box, tags, next/prev articles and bottom sharing
https://www.screencast.com/t/jZLFEJXDO
I could give you a quick fix to further overwrite this code, but it would be better to remove it. Please check all the theme panel Custom code sections and remove it if it is present there. Mainly check the Custom HTML and Custom CSS sections.
Hi there
Thank you so much, your screenshot gave me an idea where to check and I found the problem. All fixed now
Thanks much
Ciska
