I am aware of the fact that I could manually (and given the fact that a news site is constantly updating pretty much theoretically) hide certain posts or categories form individual modules/ or blocks with images.
but since there are a few nice layout-options I’d like to combine (like for example a big grid2, followed by block 2 and finally a block 21…) I’d like to know if there isn’t such an easy option as a click of a button to make sure that the automatic display of post-teasers isn’t resulting in repeated posts in each block (I’ve seen that as a feature in other themes when I was still searching for the right one and even though Newspaper and VC convinced me completely with the best of several worlds I can’t think of any other solution than a pretty complicated and much into the details of single post-ids digging solution to achieve this on my homepage while wnating to show my latest posts of all categories in different styles).
Am I missing something?
(I hope so!)
Cheers!
Hello Vittorio,
If you want to use these Visual Composer elements and you want to have unique posts for each Block/Grid you have two possibilities in order to achieve as you want. First would be to use unique articles option for your page, like this -> http://screencast.com/t/AiRje2Gkoij (the unique articles do not work with pagination but only without it) or you can use offset method for your elements, like this -> http://screencast.com/t/d0v7ZVUAJUQB -> http://screencast.com/t/BKQs54zQCeji -> http://screencast.com/t/bdsx0l3b In both of cases you will not have posts duplicate.
Thank you for the message!
Hey Catalin,
I can’t find these Unique Articles in the currently TagDiv page builder.
Could you help me out with that?
Hello ,@heitoradines,
Please check this tutorial from here and give it a try: https://forum.tagdiv.com/unique-articles/ => https://www.screencast.com/t/wleMylhPm
