Background ad click problem in single
I am using Newspaper in two blogs. In both I have using the Background Click Ad options with the same configuration.
In one it works ok in index:
http://foromoviles.com
And single:
http://foromoviles.com/la-garantia-de-los-moviles-mi-historia-con-lg/
But in the other it works in index:
http://faqsandroid.com/
But not in single:
http://faqsandroid.com/orange-dive-70/
I have tried changing:
  • Child Theme
  • functions.php
  • Custom CSS
  • ad links
    But nothig works.
    Can you help me?
    Thanks in advance.
  • This topic was modified 11 years by bbmoob.
I see that you still use the old version of the theme for http://faqsandroid.com/
Please try thsi custom css in Theme Panel > Custom Css:
body {
cursor: pointer !important;
.container, .container.td-page-wrap {
cursor: default;
