Background ad. Questions and Problem
1) I would like to use a background ad. However I set it up and it seems not to be clickable. Is there a problem?
2) Having a full-width header is quite important to our design and layout. Is there anyway in which to use both a background image whilst keeping a full-width header?
Website
http://www.circusbazaar.com
Thanks in advance
Shane
1. I’ve checked the background click ad functionality on my side and works fine. Please make sure that you set your background ad according with our documentation: https://forum.tagdiv.com/newsmag-background-ads/ deactivate all plugins except Visual Composer, clear all caches and test again.
2. When a background-image it’s used the theme switch in boxed layout all content, including the header. This was the original implementation and to change it are required many customizations in theme’s files. This is a complex task and unfortunately I can’t provide a solution now. If you need this and you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you as we can’t offer customization services at the moment.
