Background ADS Problem
so well i hope anyone can help me.
The Problem is with the Background + ADs i use a picture and a Link. but the Problem is, not the complete picuture is click available just 50%
up is not working
donw is working
sample
https://ibb.co/mHxQ7kr
site
https://www.playstationinfo.de/
Hase anyone a idea what can i do, to make the complete banner click available, not just 50%?
Thanks for helping
I add next problem with this issue… …if you move mouse pointer to footer area pointer will be still hand not arrow.
Please try to use this custom code CSS
.td-header-template-wrap,
.td-footer-template-wrap {
max-width: 1164px!important;
margin-left:auto;
margin-right:auto;
Please set the code in Theme Panel -> Custom Code -> Custom CSS.
Hello Anamaria,
thanks for the fast helping and it works 🙂
May the Force be with you
Hi, i tesed your CSS hotfix -> Header sticky menu on desktop moves to the right and mouse pointer on footer area is still hand (not arrow).
  • This reply was modified 5 years by Henrieta.
.td-footer-template-wrap,
.td-header-desktop-sticky-wrap{
margin-left:auto;
margin-right:auto;
cursor:default;
