Background Body Not Cover All Template
Hello i have issue with template i tried implement block adblock script which is have background body..but i have issue with background seems like it not cover all template
i attached screenshots for reference
View post on imgur.com
It is a z-index issue, try to increase it like in your code if it is possible – http://screencast.com/t/MThui2NGhk5
Hello can you explain more details which code need to change?
I see that you use the custom css that I provided above and it works fine. I’m not sure how you added the ad, there is an inline css on your div containers that you have to change – http://screencast.com/t/5DblX2Hd
So the z-index value must be bigger than the header’s value – http://screencast.com/t/ttU8hOVmZU
Or you can use the above custom css, like I said it works fine.
