I’m trying to set a URL ad for my background, but it’s not working. It shows as clickable, but nothing happens when it’s clicked.
Please check: http://www.thewalkingdead.com.br/
I can provide admin access if needed.
Thanks in advance,
I just tested the click ad on my end but the error is not there. It works as expected. This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
