I had this problem with the previous version too and switched back to an older version of the theme.
While I have a dark background color when I updated the theme in 7.8.1 you see the main content turn white while header and footer keep the dark color. Please advise. https://emvolos.gr/category/athlitismos/
The theme background does not affect the content, the header or the footer. The theme background color is just the outside of the theme. It does not affect any at all content.
There is no setting to change the main content background. This was never part of the theme so updating or switching to an older version will have no impact on your content color. The white background always was hard-coded in the theme css. Only the black theme demo changes the main content to black. Maybe you simply changed
demos after updating.
Thank you Bogdan.
This morning it looked ok but yesterday when I updated it looked like this:
So you see the dark body color didn’t go all the way down and stopped after the Big Grid. May be it was the cache used on the Server I don’t know.
So thanks for the fast answer.
