background does not work on the element
background does not work on the element, being of color or image it does not appear on the website
https://imgur.com/a/AprOQ
I have tested the row background color on a text element like you mention
– https://www.screencast.com/t/ZOjdgfzGQEdC
The background color is applied properly
– https://www.screencast.com/t/O5ZYhxklTDB
Setting a background on the text element itself works as well
– https://www.screencast.com/t/zGHS2avUHBL
– https://www.screencast.com/t/1TkFe2jE
I used the Visual composer provided in the theme package in the tests.
