Hello bobmak,
Unfortunately, this kind of plugin is not tested with our theme and therefore we have no idea about the theme behavior with this untested plugin, sorry! Also, we cannot provide support for untested plugins, sorry! As a suggestion, you should try using the AdRotate plugin and check the results. Many of our users have used it, and they are satisfied with its functionality.
Hello bobmak,
You should put it into the area where you want to appear on your website. For example, if you are using the post template style 1, you can add it below the author box section, like this -> https://www.screencast.com/t/KviSUJLYrns If you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
