Banner Audience NetworkFacebook Not showing in mobile system
http://www.carpresent.com/
Wait for answer
Hello komsak,
Please keep in mind that our theme has been designed to use only the Google Adsense code. This type of Ad which you have referred above was not tested with our theme, and we cannot say for sure if it will work or not with the theme, sorry! For more information about our Ads, please consult our documentation here -> https://forum.tagdiv.com/header-ads-adsense/ Notice that if you want to bring best results in our theme, you should setup your Ads according to our guide. Otherwise, you might get some errors, sorry! Most likely, for this type of Ads, is needed to make some adjustments that theme to recognize the source code and we cannot provide the additional implementation for this, sorry!
