Hello hemiargus,
Sorry for the delay but please notice that we treat our customers from oldest to newest and if you will make any bump, your question will be put at the top of the forum and will become newer and that’s why it appears this delay. Also, please notice that here you can see our Support Hours -> http://screencast.com/t/K1pbx14Wi and also, we answer on the forum from oldest to newest, respecting our program.
Unfortunately, our theme does not recognize two ad code in the same Ad spot, like Article Top Ad, for example, sorry! Where you want to display two Ads on your website? If you want on the page, please notice that you can use the Visual Composer Ad Spot Block for each desired ad, like this -> http://screencast.com/t/StYtMttI2 Also, if you want to add more than one ad for posts, you can directly add the shortcode in post editor, like this -> http://screencast.com/t/JUASB76UgLf -> http://screencast.com/t/SHMGBwCnkd To bring best results, please ensure that you have entered the ad code in custom ad 1 field, like this -> http://screencast.com/t/J0J3z5y3cvRD
Hope this helps!
Hello hemiargus,
If you want this adding to be automatically for each post, please notice that you will have to edit the td_module_single_base.php core file and with do_shortcode method you can add your Custom Ad Spot, like this -> http://screencast.com/t/jqDqmXvmV Please keep in mind that if you want to bring best results on tablets and mobile devices you will need to do some additional customizations with CSS. This is not a simple task and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry! Above, I gave you a possible way how could you do this.
