Banner Problem on Homepage – Body td-affix
Hello
We build our website http://enybusiness.ch/ with newspaper theme and install evrything. Everything looks fine with all browsers. But with Firefox you will get the problem on the main page. The banner will not fully showed.
If you scroll down, the banner will be shoew. As soon you scroll up, you will lose the banner. Any idea about that?
Thx
Hi Bogdan, I tried everything, but still same problem… Im confused because is it just on firefox… All other browsers works fine…
Any other idea?
  • This reply was modified 8 years by Morthen.
Here different code. With first one the banner will looks fold. The second one are good:
<body class=”home page-template-default page page-id-147 eny-business global-block-template-12 td-art-creek td-full-layout td-js-loaded” itemscope=”itemscope” itemtype=”http://schema.org/WebPage”&gt;
<body class=”home page-template-default page page-id-147 eny-business global-block-template-12 td-art-creek td-full-layout td-js-loaded body-td-affix” itemscope=”itemscope” itemtype=”http://schema.org/WebPage”&gt;
Indeed this is unusual, the art creek demo is designed the same and this issue is not happening on Firefox. Please try to temporarily remove the custom CSS code you have in the theme panel affecting the image box. Check if this solves the issue.
Hi Simion
Already remove and test it… But same problem. Something happens, if I scroll page up on header. Look the code which change… Do you need access on admin?
I have inspected the website on Firefox again, and I see that your removed the code. The issue is solved from what I can see
– https://www.screencast.com/t/v5YPXHO2
The problem with the top row is no longer happening, please check again.
