Best practice for adding a basic td composer block
Hi, if we just want to register a td composer block which displays a simple piece of html based on conditional logic is there a basic block file layout which we need to adhere to?
Hello !
You can use the column text element in order to render shortcodes or use HTML codes. Simply copy the shortcode and insert it in the text area of the column text as you can see here: https://www.screencast.com/t/UEMEsVKog
