Best solution to post as link
Hello, I am using new newspaper on http://www.xczech.com and it is insanly cool template. Thanks a lot. I am preparing site and I would like to ask how to make post as link.
I expain what I need:
I need to make some posts on main page as links to outside of main site. I have crowdfunding subsite make on different template and I want to post it from the mainpage. Please if you can give me advice how is best solution to do.
Unfortunately the theme doesn’t have an feature like that but you can add the the link to your desired post in post’s editor and link it to the external source then on front page you need to use module 1 because the other modules don’t display the link in the excerpt or just add the custom link to the custom excerpt field, like this: http://screencast.com/t/Y6PBcAJOg result: http://screencast.com/t/cQzsuvtQs
Here is how to add a custom link: http://screencast.com/t/38CgXF5CV9v
You can also try to use a plugin like Page Links To: https://wordpress.org/plugins/page-links-to/ to gain that accessibility.
