Best Thumbnail Quality
The quality of the featured image on my site seems to have been downgraded.
I tried to put this code:
add_filter( 'jpeg_quality', create_function( '', 'return 100;' ) ); but it don’t work
Is there a way to increase the quality of the featured image?
Thank you
We could take a look at the thumbnails and see if there is a problem. If you use high quality images originally, then the resulting thumbnails should be of quality as well, just like in the theme demo website
– https://demo.tagdiv.com/newspaper/
So there would be no need to increase the quality of a quality image.
Thank you
