What is the best way to globally change fonts on the theme? I have set the fonts in the Theme panel to the correct font and set all the widgets to use “default font” however, it still does not apply to all elements of the site. I want to avoid setting the font on each individual widget to make it easy to update globally in future. Is there a way to do this within the confines of the theme settings, or do I need to just use global CSS code to override the theme?
If you install a Pro Prebuilt Website the changes from the Theme Panel for fonts will not apply, to change the font on block/post you can edit with tagDiv Composer -> https://prnt.sc/10grx77 , select the block/post and in Style, you can change the font => https://www.screencast.com/t/sUE7ug4UIAR5 also, after you can copy the style and paste it -> https://i.imgur.com/WCHxXlr.png
This is a video about how to change the fonts => https://www.youtube.com/watch?v=jQvA64uTLkI
Hope this helps you!
