Best way to put spacing between bullets?
Hello folks. In my blog posts, I tend to use a few bullet lists. But I would prefer that there is a single space under each item of the bullet list.
What is the best way to accomplish this? Up to now, I’ve had to place a <br> in the HTML code. Is there an easier, mor automated way to make this happen?
Thanks,
Rich
Edward, thanks.
The only question I have is…
Where exactly do I put that code? Does it go somewhere within the Theme Panel? Can you show me by screen capture?
I went into my Theme Panel >> Custom Code >> and then entered the code.
See here: https://www.screencast.com/t/N4wW5W0gxR
Is that correct?
Rich
That is correct, CSS code can be entered in the Theme panel->Custom CSS code section. It will be loaded and applied in the website.
