Better or More Control of Module/Block Cropping For Mobile
1) Is there a way to get more precise cropping?
I have logos that need to be precisely cropped. So If I use a larger photo, to produce a higher res output, the photos get cropped.
EX: So on a desktop the logo reads “Google,” while on the mobile, the cropped version reads “oogl,” which isn’t going to work. lol 😉
2) Also, M10 and M11 doesn’t show any excerpt on mobile but does on desktop. Is this normal function?
1. Each module use a the same thumbnail on all devices, just for some modules it is used css code to set a specific size on mobiles. For example module 11 use this thumb – http://screencast.com/t/0uKx9ZBxenYw which is resized using css on mobile(it is not created another thumb) – http://screencast.com/t/ZxlfFcO8
2. Yes this is how these modules were designed to not use excerpt on mobiles(the excerpt is hidden) – http://screencast.com/t/jN6qFgZKS
