Better related posts
I use only one category per post and not that many tags (sometimes none). So, in the category “recipes”, the related posts always show the same 3 most recent post in that category.
I want to change it to literally anything else. Even just to get it random posts. How do I do that?
The related articles section will show posts that share at least one category or tag (depending on the chosen setting) with the post that is currently viewed
https://forum.tagdiv.com/related-articles/
The posts will be sorted by latest and there is no setting to change this sorting by a setting. Only by code, here are some similar topics, if you want to do it
https://forum.tagdiv.com/topic/filtering-related-articles-at-bottom-of-post/
https://forum.tagdiv.com/topic/remove-category-from-related-articles-filter/
