Big error on mobile
Hello, I am getting following error while accessing the website from mobile.
wp booster error:
td_api_base::mark_used_on_page : a component with the ID: tdx_options is not set.
/home/myserver/public_html/websitefolder/wp-content/themes/Newspaper/includes/wp_booster/td_api.php
wp booster error:
Missing parameter: 'file'
/home/myserver/public_html/websitefolder/wp-content/themes/Newspaper/includes/wp_booster/td_autoload_classes.php
Fatal error: Class 'tdx_options' not found in/home/myserver/public_html/websitefolder/wp-content/plugins/td-woo-label/class-td-woo-label-panel-settings.php on line75
  • This topic was modified 10 years by jatinsoni. Reason: formatting
Please try to disable all plugins except visual composer, clear cache and reset cdn files if you use it.
Then try to set hit the save button in the theme panel by changing a few options around.
Let us know if you still have this issue.
This was happening due to tagDiv Woo Label plugin. Do you have any idea why it is happening? It is important to me as I am going to implement Woocommerce to my website.
Unfortunately due to the nature of newspaper 7, these 2 plugins (wooinvoice and woolabel) were removed from the theme package and are no longer tested in the current version. We are sorry for the inconvenience caused. You can still use woocommerce with our theme and benefit from all it’s features as it is tested and working properly.
