Big Grid 1 and 2, problems on Newspaper 6 and 6.1
Hi, there is a problem with BigGrid1 and BigGrid2 on both Newspaper 6.0 and Newspaper 6.1.
I provide you with a screenshot as how they look.
  • This topic was modified 11 years by neakriti.
I have just install the fresh new update and i still have the problem with the Big Grid 2. It work’s with the the theme, but when i use the child theme i have the same problem.
I hope the update will fix this point. 🙁
Yup, issues still there with child themes.
Ok, here is a little CSS fix for the Big Grid 2. It should work. 🙂
Just paste this in Newspaper / Theme panel / Custom CSS.
.td_block_big_grid_2 .td-small-thumb .td-module-thumb {
width: 305px;
Yes, this fixes the problem when it comes to desktop screens. When reducing the width of the browser, the problem re-appears.
It would be nice if we had an out of the box fix for that problem in the next update.
1) If we add the line
@import url(“../Newspaper/style.css”);
at the style.css of the child theme
2) if we edit the functions.php file in the child theme and remove the lines
add the parent style + style.css from this folder
add_action( ‘wp_enqueue_scripts’, ‘theme_enqueue_styles’ );
function theme_enqueue_styles() {
wp_enqueue_style(‘td-theme’, get_template_directory_uri() . ‘/style.css’, ”, ‘6c’, ‘all’ );
wp_enqueue_style(‘td-theme-child’, get_stylesheet_directory_uri() . ‘/style.css’, array(‘td-theme’));
then the child theme works ok with BigGrid… I don’t know if thats ok to do….
  • This reply was modified 11 years by neakriti.
No, my bad, it doesn’t work 🙁
Anyway, tagdiv knows what they do, they’ll fix it for sure
Hello fellow crime fighters,
Open up the functions.php from the child theme and add 1000 priority to the wp_enqueue_scripts action:
add_action( 'wp_enqueue_scripts', 'theme_enqueue_styles', 1000);
Dude, you da hero!
It’s not working from my side. 🙁
@nebulonni
Please send an email at contact@tagdiv.com , paste a link to this conversation and provide wp-admin access so i can take a look.
Replied via email. For others who may want to try this: make sure you just modify the existing code like this – http://screencast.com/t/ErYFjudLd
