https://s13.postimg.org/ecidekcqv/Untitled.png Take a look and you will see what I mean, and also I want to know a way that I will not need to crop all my images at the same height and they will still be in line if you understand me…
Hello aleksandarcasual,
Notice that your image is too small than your Big Grid, big thumb. You should load a bigger image than this or you can use such a plugin which has a functionality to regenerate the thumbs and enlarge the image like Thumbnails Regenerate with Force Regenerate. You can try them, clear all the caches and check the results. Should works.
