Hello rodmvin,
Please ensure that you are using the latest version of Visual Composer (v. 4.11.2), clear all cache and check again the results. Also, please make sure that this problem does not come from untested plugins which interact with the theme and cause this issue. We do not have bad reports in this regards and I have tested this sorting on my side and everything seems to work as properly.
