I have some problem with the BIG Grid block, as you can see from here http://prntscr.com/bdt33t some of the images are shifting at the bottom is seems size problem? what do you think?
Best,
Fabio
Hello ZestMedia,
Please ensure that you have using the latest version of the theme and also, you have updated your required plugins to the latest version of them (Visual Composer 4.11.2 and Social Counter 4.1) Also, please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
Also, if your problem is still there after these tips, please provide your website URL so I can inspect it closer your Big Grid and also, so I will be able to provide a more accurate response in this regard.
Hello ZestMedia,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect your setup page. Also, please provide the link of this topic so we can identify you.
