BIG GRID FLEX 2 PROBLEM
Is there a way to hide the Big Grid Flex 2 only in the mobile version?
I like it for all versions except mobile because the scroll bar is annoying.
I’d like it to always be displayed except in the mobile version, but if I remove it, it disappears from all four screen versions.
Or is there a way to hide the Big Grid Flex 2 posts with the scroll bar only in the mobile version?
If you want to hide it, then you can use the tagDiv composer, select the mobile viewport, select the Big Grid Flex 2, and in the CSS tab, use the option for displaying the element – https://i.imgur.com/n8uXzUr.png. This option will hide the element on that viewport.
To see all hidden elements you can use the option from the manager – https://i.imgur.com/vg1bFfx.png
