Hello to the team!
I’m using the big grid flex on the home page ( http://www.pinballmag.fr ). On the classic web version, no problem of functioning. However, as soon as you use the mobile version, it is impossible to click on the images and thus to read the articles. This remains unresolved.
Best regards
Did you use any custom code to display this block? normally it should have that scroll bar like this https://i.imgur.com/9R2qZpD.png
Also, if you add that block from Composer, the result is the same, doesn’t it work?
Yes, I add that block from Composer and I do’nt use a special code and it’s doesn’t work… Any idea ?
I will like to take a deep look at this situation. If you agree, please make a full backup and provide it via email at contact@tagdiv.com wp-admin access. Also include the link of this topic to can identify you. We’ll check it as soon as possible.
