Big Grid Not Showing Properly, Please Help
Whichever Big Grid im using, Big Grid is not showing properly, suddenly, please tell how i fix this?
https://1drv.ms/u/s!AkXY4bJUGBAMgux31wIA4fwwQgaI1w
website: civilution.eu
Had to change ‘featured image placeholder’
If you want to change the Featured Image Placeholder, you need to change the images from here -> https://www.screencast.com/t/zFo59GS038Very important is to maintain the same image title. Clear all the caches, purge CDN files and check the results.
Already figured it out, but thanks anyway
